PHP Version 8.0.31 |
| System | Linux srv05.hostingrd.pl 5.14.0-687.23.2.el9_8.x86_64 #1 SMP PREEMPT_DYNAMIC Wed Jul 8 19:22:59 EDT 2026 x86_64 |
| Build Date | Nov 5 2026 00:00:00 |
| Build System | Linux buildfarm17-new.corp.cloudlinux.com 5.14.0-687.59.1.el9_8.x86_64 #1 SMP PREEMPT_DYNAMIC Wed Oct 21 06:02:14 EDT 2026 x86_64 x86_64 x86_64 GNU/Linux |
| Configure Command | './configure' '--build=x86_64-redhat-linux-gnu' '--host=x86_64-redhat-linux-gnu' '--program-prefix=' '--disable-dependency-tracking' '--prefix=/opt/cpanel/ea-php80/root/usr' '--exec-prefix=/opt/cpanel/ea-php80/root/usr' '--bindir=/opt/cpanel/ea-php80/root/usr/bin' '--sbindir=/opt/cpanel/ea-php80/root/usr/sbin' '--sysconfdir=/opt/cpanel/ea-php80/root/etc' '--datadir=/opt/cpanel/ea-php80/root/usr/share' '--includedir=/opt/cpanel/ea-php80/root/usr/include' '--libdir=/opt/cpanel/ea-php80/root/usr/lib64' '--libexecdir=/opt/cpanel/ea-php80/root/usr/libexec' '--localstatedir=/opt/cpanel/ea-php80/root/var' '--sharedstatedir=/opt/cpanel/ea-php80/root/var/lib' '--mandir=/opt/cpanel/ea-php80/root/usr/share/man' '--infodir=/opt/cpanel/ea-php80/root/usr/share/info' '--cache-file=../config.cache' '--with-libdir=lib64' '--with-config-file-path=/opt/cpanel/ea-php80/root/etc' '--with-config-file-scan-dir=/opt/cpanel/ea-php80/root/etc/php.d' '--disable-debug' '--with-password-argon2=/opt/cpanel/libargon2' '--with-pic' '--without-pear' '--with-bz2' '--with-freetype' '--with-xpm' '--without-gdbm' '--with-gettext' '--with-iconv' '--with-jpeg' '--with-openssl' '--with-openssl=/usr' '--with-pcre-regex=/usr' '--with-zlib' '--with-layout=GNU' '--enable-exif' '--enable-ftp' '--enable-sockets' '--with-kerberos' '--enable-shmop' '--with-sodium=shared' '--with-libxml' '--with-system-tzdata' '--with-mhash' '--libdir=/opt/cpanel/ea-php80/root/usr/lib64/php' '--enable-pcntl' '--enable-opcache' '--enable-phpdbg' '--with-imap=shared,/opt/cpanel/ea-libc-client' '--with-imap-ssl' '--enable-mbstring=shared' '--enable-litespeed' '--with-webp' '--enable-gd=shared' '--with-gmp=shared' '--enable-calendar=shared' '--enable-bcmath=shared' '--with-bz2=shared' '--enable-ctype=shared' '--enable-dba=shared' '--with-db4=/usr' '--with-tcadb=/usr' '--enable-exif=shared' '--enable-ftp=shared' '--with-gettext=shared' '--with-iconv=shared' '--enable-sockets=shared' '--enable-tokenizer=shared' '--with-xmlrpc=shared' '--with-ldap=shared' '--with-ldap-sasl' '--enable-mysqlnd=shared' '--with-mysqli=shared,mysqlnd' '--with-mysql-sock=/var/lib/mysql/mysql.sock' '--enable-dom=shared' '--with-pgsql=shared' '--enable-simplexml=shared' '--enable-xml=shared' '--with-snmp=shared,/usr' '--enable-soap=shared' '--with-xsl=shared,/usr' '--enable-xmlreader=shared' '--enable-xmlwriter=shared' '--with-curl=shared' '--enable-pdo=shared' '--with-pdo-odbc=shared,unixODBC,/usr' '--with-pdo-mysql=shared,mysqlnd' '--with-pdo-pgsql=shared,/usr' '--with-pdo-sqlite=shared,/usr' '--with-sqlite3=shared,/usr' '--enable-json=shared' '--with-zip=shared' '--without-readline' '--with-libedit' '--with-pspell=shared' '--enable-phar=shared' '--with-tidy=shared,/opt/cpanel/libtidy' '--enable-sysvmsg=shared' '--enable-sysvshm=shared' '--enable-sysvsem=shared' '--enable-shmop=shared' '--enable-posix=shared' '--with-unixODBC=shared,/usr' '--enable-intl=shared' '--with-enchant=shared,/usr' '--enable-fileinfo=shared' 'build_alias=x86_64-redhat-linux-gnu' 'host_alias=x86_64-redhat-linux-gnu' 'PKG_CONFIG_PATH=/opt/cpanel/ea-php80/root/usr/lib64/pkgconfig:/opt/cpanel/ea-php80/root/usr/share/pkgconfig:/usr/lib64/pkgconfig:/opt/cpanel/ea-oniguruma/lib64/pkgconfig:/opt/cpanel/libargon2/lib64/pkgconfig' 'CFLAGS=-O2 -fno-lto -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m64 -march=x86-64-v2 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-strict-aliasing -Wno-pointer-sign -mshstk' 'CXXFLAGS=-O2 -flto=auto -ffat-lto-objects -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m64 -march=x86-64-v2 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection' 'KERBEROS_CFLAGS=-I/usr/include' 'KERBEROS_LIBS=-L/usr/lib64' 'JPEG_CFLAGS=-I/usr/include' 'JPEG_LIBS=-L/usr/lib64 -ljpeg' 'SASL_CFLAGS=-I/usr/include' 'SASL_LIBS=-L/usr/lib64' 'LIBZIP_CFLAGS=-I/opt/cpanel/ea-libzip/include' 'LIBZIP_LIBS=-L/opt/cpanel/ea-libzip/lib64 -lzip' 'LT_SYS_LIBRARY_PATH=/opt/cpanel/ea-php80/root/usr/lib64:' |
| Server API | lsapi V8.3 CloudLinux 1.3 |
| Virtual Directory Support | disabled |
| Configuration File (php.ini) Path | /opt/cpanel/ea-php80/root/etc |
| Loaded Configuration File | /opt/cpanel/ea-php80/root/etc/php.ini |
| Scan this dir for additional .ini files | /opt/cpanel/ea-php80/root/etc/php.d |
| Additional .ini files parsed | /opt/cpanel/ea-php80/root/etc/php.d/20-bcmath.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-bz2.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-calendar.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-ctype.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-curl.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-dba.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-dom.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-enchant.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-exif.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-fileinfo.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-ftp.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-gd.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-gmp.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-iconv.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-imap.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-intl.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-ldap.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-mbstring.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-mysqlnd.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-odbc.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-pdo.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-pgsql.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-phar.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-posix.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-pspell.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-simplexml.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-snmp.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-soap.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-sockets.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-sqlite3.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-tidy.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-tokenizer.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-xml.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-xmlwriter.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-xsl.ini, /opt/cpanel/ea-php80/root/etc/php.d/20-zip.ini, /opt/cpanel/ea-php80/root/etc/php.d/30-mysqli.ini, /opt/cpanel/ea-php80/root/etc/php.d/30-pdo_mysql.ini, /opt/cpanel/ea-php80/root/etc/php.d/30-pdo_odbc.ini, /opt/cpanel/ea-php80/root/etc/php.d/30-pdo_pgsql.ini, /opt/cpanel/ea-php80/root/etc/php.d/30-pdo_sqlite.ini, /opt/cpanel/ea-php80/root/etc/php.d/30-xmlreader.ini, /opt/cpanel/ea-php80/root/etc/php.d/50-redis.ini, /opt/cpanel/ea-php80/root/etc/php.d/i360.ini, /opt/cpanel/ea-php80/root/etc/php.d/memcached.ini, /opt/cpanel/ea-php80/root/etc/php.d/sourceguardian.ini, /opt/cpanel/ea-php80/root/etc/php.d/zzz-cve-2026-109618.ini, /opt/cpanel/ea-php80/root/etc/php.d/zzzzzzz-pecl.ini |
| PHP API | 20200930 |
| PHP Extension | 20200930 |
| Zend Extension | 420200930 |
| Zend Extension Build | API420200930,NTS |
| PHP Extension Build | API20200930,NTS |
| Debug Build | no |
| Thread Safety | disabled |
| Zend Signal Handling | enabled |
| Zend Memory Manager | enabled |
| Zend Multibyte Support | provided by mbstring |
| IPv6 Support | enabled |
| DTrace Support | disabled |
| Registered PHP Streams | https, ftps, compress.zlib, php, file, glob, data, http, ftp, compress.bzip2, phar, zip |
| Registered Stream Socket Transports | tcp, udp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2, tlsv1.3 |
| Registered Stream Filters | zlib.*, string.rot13, string.toupper, string.tolower, convert.*, consumed, dechunk, bzip2.*, convert.iconv.* |
Zend Engine v4.0.30, Copyright (c) Zend Technologies |
| BCMath support | enabled |
| Directive | Local Value | Master Value |
| bcmath.scale | 0 | 0 |
| BZip2 Support | Enabled |
| Stream Wrapper support | compress.bzip2:// |
| Stream Filter support | bzip2.decompress, bzip2.compress |
| BZip2 Version | 1.0.8, 13-Jul-2019 |
| Calendar support | enabled |
| PHP Version | 8.0.31 |
| allow_url_fopen | On | On |
| allow_url_include | Off | Off |
| arg_separator.input | & | & |
| arg_separator.output | & | & |
| auto_append_file | no value | no value |
| auto_globals_jit | On | On |
| auto_prepend_file | no value | no value |
| browscap | no value | no value |
| default_charset | UTF-8 | UTF-8 |
| default_mimetype | text/html | text/html |
| disable_classes | no value | no value |
| disable_functions | no value | no value |
| display_errors | Off | Off |
| display_startup_errors | Off | Off |
| doc_root | no value | no value |
| docref_ext | no value | no value |
| docref_root | no value | no value |
| enable_dl | On | On |
| enable_post_data_reading | On | On |
| error_append_string | no value | no value |
| error_log | error_log | error_log |
| error_prepend_string | no value | no value |
| error_reporting | 32759 | 32759 |
| expose_php | Off | Off |
| extension_dir | /opt/cpanel/ea-php80/root/usr/lib64/php/modules | /opt/cpanel/ea-php80/root/usr/lib64/php/modules |
| file_uploads | On | On |
| hard_timeout | 2 | 2 |
| highlight.comment | #FF8000 | #FF8000 |
| highlight.default | #0000BB | #0000BB |
| highlight.html | #000000 | #000000 |
| highlight.keyword | #007700 | #007700 |
| highlight.string | #DD0000 | #DD0000 |
| html_errors | On | On |
| ignore_repeated_errors | Off | Off |
| ignore_repeated_source | Off | Off |
| ignore_user_abort | Off | Off |
| implicit_flush | Off | Off |
| include_path | .:/opt/cpanel/ea-php80/root/usr/share/pear | .:/opt/cpanel/ea-php80/root/usr/share/pear |
| input_encoding | no value | no value |
| internal_encoding | no value | no value |
| log_errors | On | On |
| log_errors_max_len | 1024 | 1024 |
| mail.add_x_header | On | On |
| mail.force_extra_parameters | no value | no value |
| mail.log | no value | no value |
| max_execution_time | 180 | 180 |
| max_file_uploads | 20 | 20 |
| max_input_nesting_level | 64 | 64 |
| max_input_time | 60 | 60 |
| max_input_vars | 1000 | 1000 |
| max_multipart_body_parts | -1 | -1 |
| memory_limit | 256M | 256M |
| open_basedir | no value | no value |
| output_buffering | no value | no value |
| output_encoding | no value | no value |
| output_handler | no value | no value |
| post_max_size | 128M | 128M |
| precision | 14 | 14 |
| realpath_cache_size | 4096K | 4096K |
| realpath_cache_ttl | 120 | 120 |
| register_argc_argv | On | On |
| report_memleaks | On | On |
| report_zend_debug | Off | Off |
| request_order | GP | GP |
| sendmail_from | no value | no value |
| sendmail_path | /usr/sbin/sendmail -t -i | /usr/sbin/sendmail -t -i |
| serialize_precision | 100 | 100 |
| short_open_tag | On | On |
| SMTP | localhost | localhost |
| smtp_port | 25 | 25 |
| sys_temp_dir | no value | no value |
| syslog.facility | LOG_USER | LOG_USER |
| syslog.filter | no-ctrl | no-ctrl |
| syslog.ident | php | php |
| unserialize_callback_func | no value | no value |
| upload_max_filesize | 128M | 128M |
| upload_tmp_dir | no value | no value |
| user_dir | no value | no value |
| user_ini.cache_ttl | 300 | 300 |
| user_ini.filename | .user.ini | .user.ini |
| variables_order | GPCS | GPCS |
| xmlrpc_error_number | 0 | 0 |
| xmlrpc_errors | Off | Off |
| zend.assertions | -1 | -1 |
| zend.detect_unicode | On | On |
| zend.enable_gc | On | On |
| zend.exception_ignore_args | Off | Off |
| zend.exception_string_param_max_len | 15 | 15 |
| zend.multibyte | Off | Off |
| zend.script_encoding | no value | no value |
| zend.signal_check | Off | Off |
| ctype functions | enabled |
| cURL support | enabled |
| cURL Information | 7.76.1 |
| Age | 8 |
| Features | |
| AsynchDNS | Yes |
| CharConv | No |
| Debug | No |
| GSS-Negotiate | No |
| IDN | Yes |
| IPv6 | Yes |
| krb4 | No |
| Largefile | Yes |
| libz | Yes |
| NTLM | Yes |
| NTLMWB | Yes |
| SPNEGO | Yes |
| SSL | Yes |
| SSPI | No |
| TLS-SRP | Yes |
| HTTP2 | Yes |
| GSSAPI | Yes |
| KERBEROS5 | Yes |
| UNIX_SOCKETS | Yes |
| PSL | Yes |
| HTTPS_PROXY | Yes |
| MULTI_SSL | No |
| BROTLI | Yes |
| Protocols | dict, file, ftp, ftps, gopher, gophers, http, https, imap, imaps, ldap, ldaps, mqtt, pop3, pop3s, rtsp, scp, sftp, smb, smbs, smtp, smtps, telnet, tftp |
| Host | x86_64-redhat-linux-gnu |
| SSL Version | OpenSSL/3.5.8 |
| ZLib Version | 1.2.11 |
| libSSH Version | libssh/0.10.4/openssl/zlib |
| curl.cainfo | no value | no value |
| date/time support | enabled |
| timelib version | 2020.03 |
| "Olson" Timezone Database Version | 0.system |
| Timezone Database | internal |
| Default timezone | UTC |
| date.default_latitude | 31.7667 | 31.7667 |
| date.default_longitude | 35.2333 | 35.2333 |
| date.sunrise_zenith | 90.833333 | 90.833333 |
| date.sunset_zenith | 90.833333 | 90.833333 |
| date.timezone | UTC | UTC |
| DBA support | enabled |
| Supported handlers | cdb cdb_make db4 inifile flatfile tcadb |
| dba.default_handler | flatfile | flatfile |
| DOM/XML | enabled |
| DOM/XML API Version | 20031129 |
| libxml Version | 2.9.13 |
| HTML Support | enabled |
| XPath Support | enabled |
| XPointer Support | enabled |
| Schema Support | enabled |
| RelaxNG Support | enabled |
| enchant support | enabled |
| Libenchant Version | 1.6.0 |
| myspell | Myspell Provider | /usr/lib64/enchant/libenchant_myspell.so |
| EXIF Support | enabled |
| Supported EXIF Version | 0220 |
| Supported filetypes | JPEG, TIFF |
| Multibyte decoding support using mbstring | enabled |
| Extended EXIF tag formats | Canon, Casio, Fujifilm, Nikon, Olympus, Samsung, Panasonic, DJI, Sony, Pentax, Minolta, Sigma, Foveon, Kyocera, Ricoh, AGFA, Epson |
| exif.decode_jis_intel | JIS | JIS |
| exif.decode_jis_motorola | JIS | JIS |
| exif.decode_unicode_intel | UCS-2LE | UCS-2LE |
| exif.decode_unicode_motorola | UCS-2BE | UCS-2BE |
| exif.encode_jis | no value | no value |
| exif.encode_unicode | ISO-8859-15 | ISO-8859-15 |
| fileinfo support | enabled |
| libmagic | 539 |
| Input Validation and Filtering | enabled |
| filter.default | unsafe_raw | unsafe_raw |
| filter.default_flags | no value | no value |
| FTP support | enabled |
| FTPS support | enabled |
| GD Support | enabled |
| GD Version | bundled (2.1.0 compatible) |
| FreeType Support | enabled |
| FreeType Linkage | with freetype |
| FreeType Version | 2.10.4 |
| GIF Read Support | enabled |
| GIF Create Support | enabled |
| JPEG Support | enabled |
| libJPEG Version | 6b |
| PNG Support | enabled |
| libPNG Version | 1.6.37 |
| WBMP Support | enabled |
| XPM Support | enabled |
| libXpm Version | 30411 |
| XBM Support | enabled |
| WebP Support | enabled |
| TGA Read Support | enabled |
| gd.jpeg_ignore_warning | 1 | 1 |
| gmp support | enabled |
| GMP version | 6.2.0 |
| hash support | enabled |
| Hashing Engines | md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 sha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b crc32c fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5 |
| MHASH support | Enabled |
| MHASH API Version | Emulated Support |
| i360 param | Value |
| i360 state | activated |
| i360 mode | kill |
| i360 blamer | true |
| i360 jit compatibility mode | enabled |
| i360 zend observer mode | enabled (startup: disabled) |
| i360 zend observer mode (note) | Force-disabled: ionCube/SourceGuardian loader detected. Using the legacy execute hook to avoid an observer/loader run-time-cache crash. |
| i360 path to log data | sock:/opt/imunify360/lib/proactive.sock |
| i360 log type | 2 |
| i360 send on shtdwn | 0 |
| i360 report on kill | 0 |
| i360 db-scan | OFF |
| i360 db-markers | built-in, 8 literals, 1 exclusions |
| i360 db-markers load | no file: /usr/share/i360-php-opts/.db_markers |
| i360 build for | 8.0.30 |
| i360 signs | 2611091 |
| i360 signs path | /usr/share/i360-php-opts/sigs/8.8/.rules.v2 |
| i360 pkg ver | 8.8.2 |
| i360 hdb ver | 1794646535 |
| i360 hdb entries | 103654 |
| iconv support | enabled |
| iconv implementation | glibc |
| iconv library version | 2.34 |
| iconv.input_encoding | no value | no value |
| iconv.internal_encoding | no value | no value |
| iconv.output_encoding | no value | no value |
| imagick module | enabled |
| imagick module version | 3.7.0 |
| imagick classes | Imagick, ImagickDraw, ImagickPixel, ImagickPixelIterator, ImagickKernel |
| Imagick compiled with ImageMagick version | ImageMagick 6.9.13-17 Q16 x86_64 18482 https://legacy.imagemagick.org |
| Imagick using ImageMagick library version | ImageMagick 6.9.13-58 Q16 x86_64 19810 https://legacy.imagemagick.org |
| ImageMagick copyright | (C) 1999 ImageMagick Studio LLC |
| ImageMagick release date | 2026-10-10 |
| ImageMagick number of supported formats: | 247 |
| ImageMagick supported formats | 3FR, 3G2, 3GP, AAI, AI, APNG, ART, ARW, AVI, AVS, BGR, BGRA, BGRO, BIE, BMP, BMP2, BMP3, BRF, CAL, CALS, CANVAS, CAPTION, CIN, CIP, CLIP, CMYK, CMYKA, CR2, CR3, CRW, CUR, CUT, DATA, DCM, DCR, DCX, DDS, DFONT, DNG, DOT, DPX, DXT1, DXT5, EPDF, EPI, EPS, EPS2, EPS3, EPSF, EPSI, EPT, EPT2, EPT3, ERF, EXR, FAX, FILE, FITS, FLV, FRACTAL, FTP, FTS, G3, G4, GIF, GIF87, GRADIENT, GRAY, GRAYA, GROUP4, GV, H, HALD, HDR, HISTOGRAM, HRZ, HTM, HTML, HTTP, HTTPS, ICB, ICO, ICON, IIQ, INFO, INLINE, IPL, ISOBRL, ISOBRL6, J2C, J2K, JBG, JBIG, JNG, JNX, JP2, JPC, JPE, JPEG, JPG, JPM, JPS, JPT, JSON, K25, KDC, LABEL, M2V, M4V, MAC, MAGICK, MAP, MASK, MAT, MATTE, MEF, MIFF, MKV, MNG, MONO, MOV, MP4, MPC, MPEG, MPG, MRW, MSL, MSVG, MTV, MVG, NEF, NRW, NULL, ORF, OTB, OTF, PAL, PALM, PAM, PANGO, PATTERN, PBM, PCD, PCDS, PCL, PCT, PCX, PDB, PDF, PDFA, PEF, PES, PFA, PFB, PFM, PGM, PGX, PICON, PICT, PIX, PJPEG, PLASMA, PNG, PNG00, PNG24, PNG32, PNG48, PNG64, PNG8, PNM, POCKETMOD, PPM, PREVIEW, PS, PS2, PS3, PSB, PSD, PTIF, PWP, RADIAL-GRADIENT, RAF, RAS, RAW, RGB, RGBA, RGBO, RGF, RLA, RLE, RMF, RSVG, RW2, SCR, SCT, SFW, SGI, SHTML, SIX, SIXEL, SPARSE-COLOR, SR2, SRF, STEGANO, SUN, SVG, SVGZ, TEXT, TGA, THUMBNAIL, TIFF, TIFF64, TILE, TIM, TTC, TTF, TXT, UBRL, UBRL6, UIL, UYVY, VDA, VICAR, VID, VIDEO, VIFF, VIPS, VST, WBMP, WEBM, WEBP, WMF, WMV, WMZ, WPG, X, X3F, XBM, XC, XCF, XPM, XPS, XV, XWD, YCbCr, YCbCrA, YUV |
| imagick.allow_zero_dimension_images | 0 | 0 |
| imagick.locale_fix | 0 | 0 |
| imagick.progress_monitor | 0 | 0 |
| imagick.set_single_thread | 1 | 1 |
| imagick.shutdown_sleep_count | 10 | 10 |
| imagick.skip_version_check | 0 | 0 |
| IMAP c-Client Version | 2007f |
| SSL Support | enabled |
| Kerberos Support | enabled |
| imap.enable_insecure_rsh | Off | Off |
| Internationalization support | enabled |
| ICU version | 67.1 |
| ICU Data version | 67.1 |
| ICU Unicode version | 13.0 |
| intl.default_locale | no value | no value |
| intl.error_level | 0 | 0 |
| intl.use_exceptions | Off | Off |
| json support | enabled |
| LDAP Support | enabled |
| Total Links | 0/unlimited |
| API Version | 3001 |
| Vendor Name | OpenLDAP |
| Vendor Version | 20608 |
| SASL Support | Enabled |
| ldap.max_links | Unlimited | Unlimited |
| libXML support | active |
| libXML Compiled Version | 2.9.13 |
| libXML Loaded Version | 20913 |
| libXML streams | enabled |
| Multibyte Support | enabled |
| Multibyte string engine | libmbfl |
| HTTP input encoding translation | disabled |
| libmbfl version | 1.3.2 |
| mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1. |
| Multibyte (japanese) regex support | enabled |
| Multibyte regex (oniguruma) version | 6.9.10 |
| mbstring.detect_order | no value | no value |
| mbstring.encoding_translation | Off | Off |
| mbstring.http_input | no value | no value |
| mbstring.http_output | no value | no value |
| mbstring.http_output_conv_mimetypes | ^(text/|application/xhtml\+xml) | ^(text/|application/xhtml\+xml) |
| mbstring.internal_encoding | no value | no value |
| mbstring.language | neutral | neutral |
| mbstring.regex_retry_limit | 1000000 | 1000000 |
| mbstring.regex_stack_limit | 100000 | 100000 |
| mbstring.strict_detection | Off | Off |
| mbstring.substitute_character | no value | no value |
| memcached support | enabled |
| Version | 3.4.0 |
| libmemcached version | 1.0.18 |
| SASL support | yes |
| Session support | yes |
| igbinary support | no |
| json support | no |
| msgpack support | no |
| zstd support | no |
| memcached.compression_factor | 1.3 | 1.3 |
| memcached.compression_level | 3 | 3 |
| memcached.compression_threshold | 2000 | 2000 |
| memcached.compression_type | fastlz | fastlz |
| memcached.default_binary_protocol | Off | Off |
| memcached.default_connect_timeout | 0 | 0 |
| memcached.default_consistent_hash | Off | Off |
| memcached.item_size_limit | 0 | 0 |
| memcached.serializer | php | php |
| memcached.sess_binary_protocol | On | On |
| memcached.sess_connect_timeout | 0 | 0 |
| memcached.sess_consistent_hash | On | On |
| memcached.sess_consistent_hash_type | ketama | ketama |
| memcached.sess_lock_expire | 0 | 0 |
| memcached.sess_lock_max_wait | not set | not set |
| memcached.sess_lock_retries | 5 | 5 |
| memcached.sess_lock_wait | not set | not set |
| memcached.sess_lock_wait_max | 150 | 150 |
| memcached.sess_lock_wait_min | 150 | 150 |
| memcached.sess_locking | On | On |
| memcached.sess_number_of_replicas | 0 | 0 |
| memcached.sess_persistent | Off | Off |
| memcached.sess_prefix | memc.sess.key. | memc.sess.key. |
| memcached.sess_randomize_replica_read | Off | Off |
| memcached.sess_remove_failed_servers | Off | Off |
| memcached.sess_sasl_password | no value | no value |
| memcached.sess_sasl_username | no value | no value |
| memcached.sess_server_failure_limit | 0 | 0 |
| memcached.store_retry_count | 0 | 0 |
| MysqlI Support | enabled |
| Client API library version | mysqlnd 8.0.31 |
| Active Persistent Links | 0 |
| Inactive Persistent Links | 0 |
| Active Links | 0 |
| mysqli.allow_local_infile | Off | Off |
| mysqli.allow_persistent | On | On |
| mysqli.default_host | no value | no value |
| mysqli.default_port | 3306 | 3306 |
| mysqli.default_pw | no value | no value |
| mysqli.default_socket | /var/lib/mysql/mysql.sock | /var/lib/mysql/mysql.sock |
| mysqli.default_user | no value | no value |
| mysqli.max_links | Unlimited | Unlimited |
| mysqli.max_persistent | Unlimited | Unlimited |
| mysqli.reconnect | Off | Off |
| mysqli.rollback_on_cached_plink | Off | Off |
| mysqlnd | enabled |
| Version | mysqlnd 8.0.31 |
| Compression | supported |
| core SSL | supported |
| extended SSL | supported |
| Command buffer size | 4096 |
| Read buffer size | 32768 |
| Read timeout | 86400 |
| Collecting statistics | Yes |
| Collecting memory statistics | No |
| Tracing | n/a |
| Loaded plugins | mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_caching_sha2_password,auth_plugin_sha256_password |
| API Extensions | mysqli,pdo_mysql |
| ODBC Support | enabled |
| Active Links | 0 |
| ODBC library | unixODBC |
| ODBCVER | 0x0380 |
| ODBC_CFLAGS | -I/usr/include |
| ODBC_LFLAGS | -L/usr/lib64 |
| ODBC_LIBS | -lodbc |
| odbc.allow_persistent | On | On |
| odbc.check_persistent | On | On |
| odbc.default_cursortype | Static cursor | Static cursor |
| odbc.default_db | no value | no value |
| odbc.default_pw | no value | no value |
| odbc.default_user | no value | no value |
| odbc.defaultbinmode | return as is | return as is |
| odbc.defaultlrl | return up to 4096 bytes | return up to 4096 bytes |
| odbc.max_links | Unlimited | Unlimited |
| odbc.max_persistent | Unlimited | Unlimited |
| OpenSSL support | enabled |
| OpenSSL Library Version | OpenSSL 3.5.8 25 Aug 2026 |
| OpenSSL Header Version | OpenSSL 3.5.8 25 Aug 2026 |
| Openssl default config | /etc/pki/tls/openssl.cnf |
| openssl.cafile | no value | no value |
| openssl.capath | no value | no value |
| pcntl support | enabled |
| PCRE (Perl Compatible Regular Expressions) Support | enabled |
| PCRE Library Version | 10.35 2020-05-09 |
| PCRE Unicode Version | 13.0.0 |
| PCRE JIT Support | enabled |
| PCRE JIT Target | x86 64bit (little endian + unaligned) |
| pcre.backtrack_limit | 1000000 | 1000000 |
| pcre.jit | 1 | 1 |
| pcre.recursion_limit | 100000 | 100000 |
| PDO support | enabled |
| PDO drivers | mysql, odbc, pgsql, sqlite |
| PDO Driver for MySQL | enabled |
| Client API version | mysqlnd 8.0.31 |
| pdo_mysql.default_socket | /var/lib/mysql/mysql.sock | /var/lib/mysql/mysql.sock |
| PDO Driver for ODBC (unixODBC) | enabled |
| ODBC Connection Pooling | Enabled, strict matching |
| PDO Driver for PostgreSQL | enabled |
| PostgreSQL(libpq) Version | 13.23 |
| PDO Driver for SQLite 3.x | enabled |
| SQLite Library | 3.34.1 |
| PostgreSQL Support | enabled |
| PostgreSQL (libpq) Version | 13.23 |
| Multibyte character support | enabled |
| Active Links | 0 |
| pgsql.allow_persistent | On | On |
| pgsql.auto_reset_persistent | Off | Off |
| pgsql.ignore_notice | Off | Off |
| pgsql.log_notice | Off | Off |
| pgsql.max_links | Unlimited | Unlimited |
| pgsql.max_persistent | Unlimited | Unlimited |
| Phar: PHP Archive support | enabled |
| Phar API version | 1.1.1 |
| Phar-based phar archives | enabled |
| Tar-based phar archives | enabled |
| ZIP-based phar archives | enabled |
| gzip compression | enabled |
| bzip2 compression | enabled |
Phar based on pear/PHP_Archive, original concept by Davey Shafik. Phar fully realized by Gregory Beaver and Marcus Boerger. Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle. |
| phar.cache_list | no value | no value |
| phar.readonly | On | On |
| phar.require_hash | On | On |
| POSIX support | enabled |
| PSpell Support | enabled |
| Readline Support | enabled |
| Readline library | EditLine wrapper |
| cli.pager | no value | no value |
| cli.prompt | \b \> | \b \> |
| Redis Support | enabled |
| Redis Version | 5.3.7 |
| Redis Sentinel Version | 0.1 |
| Available serializers | php, json |
| Available compression | zstd |
| redis.arrays.algorithm | no value | no value |
| redis.arrays.auth | no value | no value |
| redis.arrays.autorehash | 0 | 0 |
| redis.arrays.connecttimeout | 0 | 0 |
| redis.arrays.consistent | 0 | 0 |
| redis.arrays.distributor | no value | no value |
| redis.arrays.functions | no value | no value |
| redis.arrays.hosts | no value | no value |
| redis.arrays.index | 0 | 0 |
| redis.arrays.lazyconnect | 0 | 0 |
| redis.arrays.names | no value | no value |
| redis.arrays.pconnect | 0 | 0 |
| redis.arrays.previous | no value | no value |
| redis.arrays.readtimeout | 0 | 0 |
| redis.arrays.retryinterval | 0 | 0 |
| redis.clusters.auth | no value | no value |
| redis.clusters.cache_slots | 0 | 0 |
| redis.clusters.persistent | 0 | 0 |
| redis.clusters.read_timeout | 0 | 0 |
| redis.clusters.seeds | no value | no value |
| redis.clusters.timeout | 0 | 0 |
| redis.pconnect.connection_limit | 0 | 0 |
| redis.pconnect.echo_check_liveness | 1 | 1 |
| redis.pconnect.pool_detect_dirty | 0 | 0 |
| redis.pconnect.pool_pattern | no value | no value |
| redis.pconnect.pool_poll_timeout | 0 | 0 |
| redis.pconnect.pooling_enabled | 1 | 1 |
| redis.session.lock_expire | 0 | 0 |
| redis.session.lock_retries | 10 | 10 |
| redis.session.lock_wait_time | 2000 | 2000 |
| redis.session.locking_enabled | 0 | 0 |
| Reflection | enabled |
| Session Support | enabled |
| Registered save handlers | files user redis rediscluster memcached |
| Registered serializer handlers | php_serialize php php_binary |
| session.auto_start | Off | Off |
| session.cache_expire | 180 | 180 |
| session.cache_limiter | nocache | nocache |
| session.cookie_domain | no value | no value |
| session.cookie_httponly | no value | no value |
| session.cookie_lifetime | 0 | 0 |
| session.cookie_path | / | / |
| session.cookie_samesite | no value | no value |
| session.cookie_secure | 0 | 0 |
| session.gc_divisor | 0 | 0 |
| session.gc_maxlifetime | 1440 | 1440 |
| session.gc_probability | 0 | 0 |
| session.lazy_write | On | On |
| session.name | PHPSESSID | PHPSESSID |
| session.referer_check | no value | no value |
| session.save_handler | files | files |
| session.save_path | /var/cpanel/php/sessions/ea-php80 | /var/cpanel/php/sessions/ea-php80 |
| session.serialize_handler | php | php |
| session.sid_bits_per_character | 4 | 4 |
| session.sid_length | 32 | 32 |
| session.upload_progress.cleanup | On | On |
| session.upload_progress.enabled | Off | Off |
| session.upload_progress.freq | 1% | 1% |
| session.upload_progress.min_freq | 1 | 1 |
| session.upload_progress.name | PHP_SESSION_UPLOAD_PROGRESS | PHP_SESSION_UPLOAD_PROGRESS |
| session.upload_progress.prefix | upload_progress_ | upload_progress_ |
| session.use_cookies | 1 | 1 |
| session.use_only_cookies | 1 | 1 |
| session.use_strict_mode | 0 | 0 |
| session.use_trans_sid | 0 | 0 |
| SimpleXML support | enabled |
| Schema support | enabled |
| NET-SNMP Support | enabled |
| NET-SNMP Version | 5.9.1 |
| Soap Client | enabled |
| Soap Server | enabled |
| soap.wsdl_cache | 1 | 1 |
| soap.wsdl_cache_dir | /tmp | /tmp |
| soap.wsdl_cache_enabled | On | On |
| soap.wsdl_cache_limit | 5 | 5 |
| soap.wsdl_cache_ttl | 86400 | 86400 |
| Sockets Support | enabled |
| SourceGuardian Loader Support | enabled |
| SourceGuardian Loader Version | 17.0.0 |
| SourceGuardian Loader Build Number | 0x00000021 |
| sourceguardian.enable_debug | 0 | 0 |
| sourceguardian.enable_vm_hybrid | 0 | 0 |
| sourceguardian.restrict_unencoded | 0 | 0 |
| SPL support | enabled |
| Interfaces | OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject |
| Classes | AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException |
| SQLite3 support | enabled |
| sqlite3.defensive | On | On |
| sqlite3.extension_dir | no value | no value |
| Dynamic Library Support | enabled |
| Path to sendmail | /usr/sbin/sendmail -t -i |
| assert.active | On | On |
| assert.bail | Off | Off |
| assert.callback | no value | no value |
| assert.exception | On | On |
| assert.warning | On | On |
| auto_detect_line_endings | Off | Off |
| default_socket_timeout | 60 | 60 |
| session.trans_sid_hosts | no value | no value |
| session.trans_sid_tags | a=href,area=href,frame=src,form= | a=href,area=href,frame=src,form= |
| unserialize_max_depth | 4096 | 4096 |
| url_rewriter.hosts | no value | no value |
| url_rewriter.tags | a=href,area=href,frame=src,input=src,form=fakeentry | a=href,area=href,frame=src,input=src,form=fakeentry |
| user_agent | no value | no value |
| Tidy support | enabled |
| libTidy Version | 5.8.0 |
| tidy.clean_output | no value | no value |
| tidy.default_config | no value | no value |
| Tokenizer Support | enabled |
| XML Support | active |
| XML Namespace Support | active |
| libxml2 Version | 2.9.13 |
| XMLReader | enabled |
| XMLWriter | enabled |
| XSL | enabled |
| libxslt Version | 1.1.34 |
| libxslt compiled against libxml Version | 2.9.13 |
| EXSLT | enabled |
| libexslt Version | 1.1.34 |
| Zip | enabled |
| Zip version | 1.19.5 |
| Libzip version | 1.12.1 |
| BZIP2 compression | Yes |
| XZ compression | Yes |
| ZSTD compression | No |
| AES-128 encryption | Yes |
| AES-192 encryption | Yes |
| AES-256 encryption | Yes |
| ZLib Support | enabled |
| Stream Wrapper | compress.zlib:// |
| Stream Filter | zlib.inflate, zlib.deflate |
| Compiled Version | 1.2.11 |
| Linked Version | 1.2.11 |
| zlib.output_compression | On | On |
| zlib.output_compression_level | -1 | -1 |
| zlib.output_handler | no value | no value |
| Module Name |
| litespeed |
| Variable | Value |
| HTTP_HOST | jakitelewizorkupic.pl.h1312765.hostingrd.pl |
| DOCUMENT_ROOT | /home/h1312765/jakitelewizorkupic.pl.h1312765.hostingrd.pl |
| PATH | /usr/local/bin:/usr/bin:/bin |
| TEMP | /tmp |
| TMP | /tmp |
| TMPDIR | /tmp |
| PWD | / |
| Variable | Value |
| $_SERVER['HTTP_HOST'] | jakitelewizorkupic.pl.h1312765.hostingrd.pl |
| $_SERVER['DOCUMENT_ROOT'] | /home/h1312765/jakitelewizorkupic.pl.h1312765.hostingrd.pl |
| $_SERVER['PATH'] | /usr/local/bin:/usr/bin:/bin |
| $_SERVER['TEMP'] | /tmp |
| $_SERVER['TMP'] | /tmp |
| $_SERVER['TMPDIR'] | /tmp |
| $_SERVER['PWD'] | / |
| $_SERVER['HTTP_ACCEPT'] | */* |
| $_SERVER['HTTP_ACCEPT_ENCODING'] | gzip, br, zstd, deflate |
| $_SERVER['CONTENT_LENGTH'] | 0 |
| $_SERVER['HTTP_USER_AGENT'] | Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com) |
| $_SERVER['UNIQUE_ID'] | avgnaxV64MRH8tWAofDR1wAAAQM |
| $_SERVER['HTTPS'] | on |
| $_SERVER['SSL_TLS_SNI'] | jakitelewizorkupic.pl.h1312765.hostingrd.pl |
| $_SERVER['HTTP2'] | on |
| $_SERVER['H2PUSH'] | off |
| $_SERVER['H2_PUSH'] | off |
| $_SERVER['H2_PUSHED'] | no value |
| $_SERVER['H2_PUSHED_ON'] | no value |
| $_SERVER['H2_STREAM_ID'] | 1 |
| $_SERVER['H2_STREAM_TAG'] | 3269164-513-1 |
| $_SERVER['SERVER_SIGNATURE'] | no value |
| $_SERVER['SERVER_SOFTWARE'] | Apache |
| $_SERVER['SERVER_NAME'] | jakitelewizorkupic.pl.h1312765.hostingrd.pl |
| $_SERVER['SERVER_ADDR'] | 195.128.154.19 |
| $_SERVER['SERVER_PORT'] | 443 |
| $_SERVER['REMOTE_ADDR'] | 216.73.217.112 |
| $_SERVER['REQUEST_SCHEME'] | https |
| $_SERVER['CONTEXT_PREFIX'] | no value |
| $_SERVER['CONTEXT_DOCUMENT_ROOT'] | /home/h1312765/jakitelewizorkupic.pl.h1312765.hostingrd.pl |
| $_SERVER['SERVER_ADMIN'] | webmaster@jakitelewizorkupic.pl.h1312765.hostingrd.pl |
| $_SERVER['SCRIPT_FILENAME'] | /home/h1312765/jakitelewizorkupic.pl.h1312765.hostingrd.pl/index.php |
| $_SERVER['REMOTE_PORT'] | 15280 |
| $_SERVER['SERVER_PROTOCOL'] | HTTP/2.0 |
| $_SERVER['REQUEST_METHOD'] | GET |
| $_SERVER['QUERY_STRING'] | no value |
| $_SERVER['REQUEST_URI'] | / |
| $_SERVER['SCRIPT_NAME'] | /index.php |
| $_SERVER['PHP_SELF'] | /index.php |
| $_SERVER['REQUEST_TIME_FLOAT'] | 1794647916.0714 |
| $_SERVER['REQUEST_TIME'] | 1794647916 |
| $_SERVER['argv'] | Array ( ) |
| $_SERVER['argc'] | 0 |
| PHP Group |
| Thies C. Arntzen, Stig Bakken, Shane Caraveo, Andi Gutmans, Rasmus Lerdorf, Sam Ruby, Sascha Schumann, Zeev Suraski, Jim Winstead, Andrei Zmievski |
| Language Design & Concept |
| Andi Gutmans, Rasmus Lerdorf, Zeev Suraski, Marcus Boerger |
| PHP Authors | |
| Contribution | Authors |
| Zend Scripting Language Engine | Andi Gutmans, Zeev Suraski, Stanislav Malyshev, Marcus Boerger, Dmitry Stogov, Xinchen Hui, Nikita Popov |
| Extension Module API | Andi Gutmans, Zeev Suraski, Andrei Zmievski |
| UNIX Build and Modularization | Stig Bakken, Sascha Schumann, Jani Taskinen, Peter Kokot |
| Windows Support | Shane Caraveo, Zeev Suraski, Wez Furlong, Pierre-Alain Joye, Anatol Belski, Kalle Sommer Nielsen |
| Server API (SAPI) Abstraction Layer | Andi Gutmans, Shane Caraveo, Zeev Suraski |
| Streams Abstraction Layer | Wez Furlong, Sara Golemon |
| PHP Data Objects Layer | Wez Furlong, Marcus Boerger, Sterling Hughes, George Schlossnagle, Ilia Alshanetsky |
| Output Handler | Zeev Suraski, Thies C. Arntzen, Marcus Boerger, Michael Wallner |
| Consistent 64 bit support | Anthony Ferrara, Anatol Belski |
| SAPI Modules | |
| Apache 2.0 Handler | Ian Holsman, Justin Erenkrantz (based on Apache 2.0 Filter code) |
| CGI / FastCGI | Rasmus Lerdorf, Stig Bakken, Shane Caraveo, Dmitry Stogov |
| CLI | Edin Kadribasic, Marcus Boerger, Johannes Schlueter, Moriyoshi Koizumi, Xinchen Hui |
| Embed | Edin Kadribasic |
| FastCGI Process Manager | Andrei Nigmatulin, dreamcat4, Antony Dovgal, Jerome Loyet |
| litespeed | George Wang |
| phpdbg | Felipe Pena, Joe Watkins, Bob Weinand |
| Module Authors | |
| Module | Authors |
| BC Math | Andi Gutmans |
| Bzip2 | Sterling Hughes |
| Calendar | Shane Caraveo, Colin Viebrock, Hartmut Holzgraefe, Wez Furlong |
| COM and .Net | Wez Furlong |
| ctype | Hartmut Holzgraefe |
| cURL | Sterling Hughes |
| Date/Time Support | Derick Rethans |
| DB-LIB (MS SQL, Sybase) | Wez Furlong, Frank M. Kromann, Adam Baratz |
| DBA | Sascha Schumann, Marcus Boerger |
| DOM | Christian Stocker, Rob Richards, Marcus Boerger |
| enchant | Pierre-Alain Joye, Ilia Alshanetsky |
| EXIF | Rasmus Lerdorf, Marcus Boerger |
| FFI | Dmitry Stogov |
| fileinfo | Ilia Alshanetsky, Pierre Alain Joye, Scott MacVicar, Derick Rethans, Anatol Belski |
| Firebird driver for PDO | Ard Biesheuvel |
| FTP | Stefan Esser, Andrew Skalski |
| GD imaging | Rasmus Lerdorf, Stig Bakken, Jim Winstead, Jouni Ahto, Ilia Alshanetsky, Pierre-Alain Joye, Marcus Boerger, Mark Randall |
| GetText | Alex Plotnick |
| GNU GMP support | Stanislav Malyshev |
| Iconv | Rui Hirokawa, Stig Bakken, Moriyoshi Koizumi |
| IMAP | Rex Logan, Mark Musone, Brian Wang, Kaj-Michael Lang, Antoni Pamies Olive, Rasmus Lerdorf, Andrew Skalski, Chuck Hagenbuch, Daniel R Kalowsky |
| Input Filter | Rasmus Lerdorf, Derick Rethans, Pierre-Alain Joye, Ilia Alshanetsky |
| Internationalization | Ed Batutis, Vladimir Iordanov, Dmitry Lakhtyuk, Stanislav Malyshev, Vadim Savchuk, Kirti Velankar |
| JSON | Jakub Zelenka, Omar Kilani, Scott MacVicar |
| LDAP | Amitay Isaacs, Eric Warnke, Rasmus Lerdorf, Gerrit Thomson, Stig Venaas |
| LIBXML | Christian Stocker, Rob Richards, Marcus Boerger, Wez Furlong, Shane Caraveo |
| Multibyte String Functions | Tsukada Takuya, Rui Hirokawa |
| MySQL driver for PDO | George Schlossnagle, Wez Furlong, Ilia Alshanetsky, Johannes Schlueter |
| MySQLi | Zak Greant, Georg Richter, Andrey Hristov, Ulf Wendel |
| MySQLnd | Andrey Hristov, Ulf Wendel, Georg Richter, Johannes Schlüter |
| OCI8 | Stig Bakken, Thies C. Arntzen, Andy Sautins, David Benson, Maxim Maletsky, Harald Radi, Antony Dovgal, Andi Gutmans, Wez Furlong, Christopher Jones, Oracle Corporation |
| ODBC driver for PDO | Wez Furlong |
| ODBC | Stig Bakken, Andreas Karajannis, Frank M. Kromann, Daniel R. Kalowsky |
| Opcache | Andi Gutmans, Zeev Suraski, Stanislav Malyshev, Dmitry Stogov, Xinchen Hui |
| OpenSSL | Stig Venaas, Wez Furlong, Sascha Kettler, Scott MacVicar, Eliot Lear |
| Oracle (OCI) driver for PDO | Wez Furlong |
| pcntl | Jason Greene, Arnaud Le Blanc |
| Perl Compatible Regexps | Andrei Zmievski |
| PHP Archive | Gregory Beaver, Marcus Boerger |
| PHP Data Objects | Wez Furlong, Marcus Boerger, Sterling Hughes, George Schlossnagle, Ilia Alshanetsky |
| PHP hash | Sara Golemon, Rasmus Lerdorf, Stefan Esser, Michael Wallner, Scott MacVicar |
| Posix | Kristian Koehntopp |
| PostgreSQL driver for PDO | Edin Kadribasic, Ilia Alshanetsky |
| PostgreSQL | Jouni Ahto, Zeev Suraski, Yasuo Ohgaki, Chris Kings-Lynne |
| Pspell | Vlad Krupin |
| Readline | Thies C. Arntzen |
| Reflection | Marcus Boerger, Timm Friebe, George Schlossnagle, Andrei Zmievski, Johannes Schlueter |
| Sessions | Sascha Schumann, Andrei Zmievski |
| Shared Memory Operations | Slava Poliakov, Ilia Alshanetsky |
| SimpleXML | Sterling Hughes, Marcus Boerger, Rob Richards |
| SNMP | Rasmus Lerdorf, Harrie Hazewinkel, Mike Jackson, Steven Lawrance, Johann Hanne, Boris Lytochkin |
| SOAP | Brad Lafountain, Shane Caraveo, Dmitry Stogov |
| Sockets | Chris Vandomelen, Sterling Hughes, Daniel Beulshausen, Jason Greene |
| Sodium | Frank Denis |
| SPL | Marcus Boerger, Etienne Kneuss |
| SQLite 3.x driver for PDO | Wez Furlong |
| SQLite3 | Scott MacVicar, Ilia Alshanetsky, Brad Dewar |
| System V Message based IPC | Wez Furlong |
| System V Semaphores | Tom May |
| System V Shared Memory | Christian Cartus |
| tidy | John Coggeshall, Ilia Alshanetsky |
| tokenizer | Andrei Zmievski, Johannes Schlueter |
| XML | Stig Bakken, Thies C. Arntzen, Sterling Hughes |
| XMLReader | Rob Richards |
| XMLWriter | Rob Richards, Pierre-Alain Joye |
| XSL | Christian Stocker, Rob Richards |
| Zip | Pierre-Alain Joye, Remi Collet |
| Zlib | Rasmus Lerdorf, Stefan Roehrich, Zeev Suraski, Jade Nicoletti, Michael Wallner |
| PHP Documentation | |
| Authors | Mehdi Achour, Friedhelm Betz, Antony Dovgal, Nuno Lopes, Hannes Magnusson, Philip Olson, Georg Richter, Damien Seguy, Jakub Vrana, Adam Harvey |
| Editor | Peter Cowburn |
| User Note Maintainers | Daniel P. Brown, Thiago Henrique Pojda |
| Other Contributors | Previously active authors, editors and other contributors are listed in the manual. |
| PHP Quality Assurance Team |
| Ilia Alshanetsky, Joerg Behrens, Antony Dovgal, Stefan Esser, Moriyoshi Koizumi, Magnus Maatta, Sebastian Nohn, Derick Rethans, Melvyn Sopacua, Pierre-Alain Joye, Dmitry Stogov, Felipe Pena, David Soria Parra, Stanislav Malyshev, Julien Pauli, Stephen Zarkos, Anatol Belski, Remi Collet, Ferenc Kovacs |
| Websites and Infrastructure team | |
| PHP Websites Team | Rasmus Lerdorf, Hannes Magnusson, Philip Olson, Lukas Kahwe Smith, Pierre-Alain Joye, Kalle Sommer Nielsen, Peter Cowburn, Adam Harvey, Ferenc Kovacs, Levi Morrison |
| Event Maintainers | Damien Seguy, Daniel P. Brown |
| Network Infrastructure | Daniel P. Brown |
| Windows Infrastructure | Alex Schoenmaker |
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net. |
